Cylinder Head Studs
Old May 7, 2003 | 05:33 AM
Shadohh's Avatar
Do you have part numbers for ARP replacement bolts for the Cam shaft Journals Cap bolts.
Cause those bitches break even with the recommended torque settings.
Old May 7, 2003 | 05:38 AM
Red's Avatar
Red
Nope... Last time I broke one of those, I picked up a handful from a local hardware store.
Old May 7, 2003 | 01:32 PM
Shadohh's Avatar
me to.
Old Mar 7, 2010 | 03:22 AM
Ryanator's Avatar
Vehicle: 2003 Hyundai Accent 22PSI Boost
the bolts you get from the hardware store are in fact a stronger bolt, just so you all know, its because they are a higher tensile strength.
Cheers Ryan
Old Mar 16, 2010 | 08:57 PM
Regit's Avatar
Vehicle: 2000 tib
since someone reopened this thread.,maybe someone else can use this info I got from ARP the other day
Beta I torque specs
Part #AM 4.500-1LB (M10x1.25 Studs) =
Arp lube =60lbs
Ultratorque(ARP)=60lbs
30 weight oil(ie10w/30)=70 lbs
Part #AU 7.250-1LB (M12x1.25 Studs) =
Arp lube=80lbs
Ultratorque(ARP)=90lbs
30 weight oil(ie 10w30)=120lbs
The M12 should be tightened in 3 steps, ie : 90lbs =30/30/30 lbs,120lbs =40/40/40 lbs
If using 30 weight oil for either stud, It should be torqued and loosened and torqued again at least 3-4 times, to reduce the friction and be properly torqued., It is recommended by ARP to use theyre new ultratorque lube as it eliminates retorquing.
