Hyundai Aftermarket
-   Turbo & Supercharge (Forced Induction) (https://www.hyundaiaftermarket.org/forum/turbo-supercharge-forced-induction-29/)
-   -   Boost spikes (https://www.hyundaiaftermarket.org/forum/turbo-supercharge-forced-induction-29/boost-spikes-41381/)
41willys Feb 22, 2007 01:49 PM
I am currently having the same problem with my car right now. My T3/T4 is just one year old and already the boost drops from 12 to 9 psi at the redline sad.gif
I am using an internal wastegate setup that's good for at least 7-8psi and I'm using a manual boost controller.
Will installing an external wastegate really solve this? I'm using a 3inch downpipe and exhaust with no cat and muffler.
I really want to hold on to 12psi..
http://memimage.cardomain.net/member...32_57_full.jpg
Hyundai4g63T Feb 22, 2007 02:28 PM
REDZMAN Feb 22, 2007 02:29 PM
I'm at school, someone split this thread. Last post is almost 2 years ago dude, start your own thread.
Alex01tib Feb 22, 2007 02:38 PM
Hey man i split this post, we dont bring up posts that are stupid old unless we really really need to.
i dont think its the wastegate, as if it was the internal wastegate running out of efficiency it would over boost, not to mention a t3/t4 can sure as hell handle 12 psi.
Try unhooking the signal to the actuator and see if it will boost past 12. if not then you have a leak in the manifold or similar
xxxmonoxidechild Feb 22, 2007 03:48 PM
thats not a internal wastegate issue at that psi with that turbo. you probably have a vac leak, or your BOV is leaking.
whats your vac pulling at idle?
hamhead Feb 22, 2007 05:32 PM
What MBC are you running? Best place to look if your not having any vacuum/boost leaks.
Denisst99 Feb 22, 2007 11:34 PM
where are you getting the boost signal from?
whjat kind of intercoler and piping sytem do you have"
what kind of exhaust system are you running?
MAXXTIB Feb 23, 2007 12:49 AM
If your running an internal gated turbo where are you running the line to the wastegate actuartor, if it's going to the compressor housing that could be your problem, you may only see 9psi at the intake manifold but in the compressor you will still be at 12psi, run the boost line from the actuator to a port on the intake manifold so it will run the wastegate from actual manifold pressure, then it should hold steady.
41willys Feb 24, 2007 10:30 PM
<div class='quotetop'>QUOTE (Alex01tib @ Feb 22 2007, 03:38 PM) <{POST_SNAPBACK}></div><div class='quotemain'>Hey man i split this post, we dont bring up posts that are stupid old unless we really really need to.
Try unhooking the signal to the actuator and see if it will boost past 12. if not then you have a leak in the manifold or similar</div>
It can sure as hell boost past 12. But it cant hold it at that.
<div class='quotetop'>QUOTE (xxxmonoxidechild @ Feb 22 2007, 04:48 PM) <{POST_SNAPBACK}></div><div class='quotemain'>thats not a internal wastegate issue at that psi with that turbo. you probably have a vac leak, or your BOV is leaking.
whats your vac pulling at idle?</div>
I have inspected vacuum lines and the BOV and I'm pretty sure I dont have leaks. My gauge reads Im at 18-20 In.Hg at idle. It has always been at this ever since.
<div class='quotetop'>QUOTE (hamhead @ Feb 22 2007, 06:32 PM) <{POST_SNAPBACK}></div><div class='quotemain'>What MBC are you running? Best place to look if your not having any vacuum/boost leaks.</div>
Im not sure of the brand, but it's a bleed type.
<div class='quotetop'>QUOTE (MaxxTib @ Feb 23 2007, 01:49 AM) <{POST_SNAPBACK}></div><div class='quotemain'>If your running an internal gated turbo where are you running the line to the wastegate actuartor, if it's going to the compressor housing that could be your problem, you may only see 9psi at the intake manifold but in the compressor you will still be at 12psi, run the boost line from the actuator to a port on the intake manifold so it will run the wastegate from actual manifold pressure, then it should hold steady.</div>
Yep my wastegate is lined from the compressor to the actuator. Okay I'll try that. smile.gif
2uniq Mar 9, 2007 07:22 PM
external Wastegate will solve your issues i had this problem 4 years ago and since i went with a Tial 38mm External gate my problems were solved.Believe it or not even on Low boost an internal gate can cause a problem....The external rectified it RIGHT AWAY
