boost controlers for tybi
please help me , im from spain. i own a 99 tybi. i would like to know if boost controler could work in my car? will i get more hps? how much it cost? can everyone install it? do i need anyting else to make the booster work? smile.gif smile.gif smile.gif
If I'm not mistaken, the term "amount of boost" is used to describe the PSI that a turbocharger on a vehicle is running at... Example would be I have a turbo running 9 PSI of boost.. or something like that. Therefore, unless you have a turbo, you really don't have any boost to control with a boost controller smile.gif
To get a turbocharger for your car is between US$2500 and $5000, depending on what you go for and how much you do yourself. Your car will be off the road for as short as 3 days, given top notch experts working long hours, to a month, given an 'average' mechanic to work on it.
This is not an easy modification by any means, and should not be done without a lot of preparation and research.
[ August 06, 2002, 10:19 PM: Message edited by: Veniston ]
