Hyundai Aftermarket
-   Turbo & Supercharge (Forced Induction) (https://www.hyundaiaftermarket.org/forum/turbo-supercharge-forced-induction-29/)
-   -   Boost Calculator ! (https://www.hyundaiaftermarket.org/forum/turbo-supercharge-forced-induction-29/boost-calculator-22968/)
FordFasteRR Dec 31, 2004 10:06 AM
Re: Safe psi?
Ok, I figure that it would be cool to share this with everyone in the other forums..
I originally posted this on elantraxd.com ..
This calculator is very simple, It only uses atmospheric pressure as a baseline so actual hp results may vary depending on many other factors, however this calculator is a great tool for getting a basic idea of your boost requirements..
check it out here: http://www.nitrousworld.com/boost_calculator.php
Enjoy !!
krazykyle Dec 31, 2004 10:51 AM
Re: Rides , discovery Channel
sweet only need to boost 94psi to reach my goal!!
FordFasteRR Dec 31, 2004 04:02 PM
Re: I need advice..
<div class='quotetop'>QUOTE (krazykyle)</div><div class='quotemain'>sweet only need to boost 94psi to reach my goal!!</div>
AEMTIB01 Dec 31, 2004 04:49 PM
Re: Ebay Coilovers - What do you think
haha i typed in 1000 hp to lol..thats funny
FordFasteRR Jan 3, 2005 09:18 PM
Re: FS: BBTB
I added some fuel information to the calculator...
zoned019 Jan 3, 2005 10:49 PM
Re: What im up to...
You will need: 14.7 PSI to make 270 bhp
You will need a 138 lph Fuel Pump
A 4 cylinder engine will need 443 CC Injectors
so this means that Tim's boosted elantra that's running at 14psi has got about 270hp...wow. im not quite sure if the injectors part is quite accurate.
CyberShark Jan 3, 2005 10:57 PM
Re: Direct Fire Ignition
That's pretty cool..fun messing with too.
FordFasteRR Jan 4, 2005 06:59 AM
Re: Cottage Fever 2005 May 23rd - May 25th
<div class='quotetop'>QUOTE (zoned019)</div><div class='quotemain'>You will need: 14.7 PSI to make 270 bhp
so this means that Tim's boosted elantra that's running at 14psi has got about 270hp...wow. im not quite sure if the injectors part is quite accurate.</div>
injector flow rate can vary with fuel pressure, however that figure is only using 80% duty cycle.. you can use smaller injectors but you will need more fuel pressure to make them flow properly.. or you can push them harder than 80% duty cycle and get away with smaller injectors, but then you risk damaging the injectors ....
As long as you have a reliable way of controlling fuel pressure, you can use bigger injectors and always have room to grow. smile.gif
hamhead Jan 5, 2005 02:52 PM
Re: Direct Fire Ignition*UPDATE*
hrm... anyone know the lph on the stock fuel pump?
silvertibbs Jan 5, 2005 03:13 PM
Re: VHR GB open to everyone
I asked that in a thread not too long ago. Nothing on webtech or anything.
So.....I dunno.
