Any 400+ horsepower cars driving around?
Old Mar 11, 2015 | 12:00 AM
  #21
Juanra's Avatar
Vehicle: 1997 Beta Swapped Accent
There is no E85 available in out pumps, that is 93 oct with 10% Ethanol and water/meth injection.
And yes we do, my NA car has 160 HP is running at 13.3 AFR.
Old Mar 11, 2015 | 01:30 AM
  #22
i8acobra's Avatar
Vehicle: '14 Ford F-150
Bigger stones (or fatter wallet) than me. I shoot for 11.7:1 on 91 octane. 12.2:1 on 100 octane.
Old Mar 11, 2015 | 03:30 AM
  #23
03tibe85's Avatar
Vehicle: 2003/Hyundai/Tiburon
That Accent must've been slipping big time on the Dyno rollers. Torque is all over the place!
Old Mar 11, 2015 | 06:09 AM
  #24
JonGTR's Avatar
Thanks for the info. You've got to be pretty close to the Walbro's limit. A 67mm throttle body is good for 700-800whp. I'm sure the 90mm makes it hard to drive at low throttle.
As I've suspected before:
This proves that you don't need a $1500 built head to make 500whp!!!
However, I'm still installing a set of $80 valve springs in case of valve float.
Old Mar 11, 2015 | 06:40 AM
  #25
Juanra's Avatar
Ohh wait, I forgot!
I do have OEm 4G63 valve springs, they measure about 12 lb more on our heads. if you don't trust then go with aftermarket, Crower are about $90.
Engendro has only Ferrea valve springs and retainers, video for reference.
[media]http://www.youtube.com/watch?v=tTs2mYCAexY&t=1m35s[/media]
Old Mar 11, 2015 | 06:58 AM
  #26
JonGTR's Avatar
That's exactly what I bought. 4g63 springs from Crower. Paid $83.58 shipped.
The bigger question is what is he using for a transmission?
Old Mar 11, 2015 | 07:48 AM
  #27
Juanra's Avatar
I'm using stock X3 tranny and waiting for it to explode, Engendro uses a 2001 RD2 modified automatic transmission.
Old Mar 11, 2015 | 01:48 PM
  #28
JonGTR's Avatar
Juanra,
What clutch are you using that holds that much torque??
Old Mar 11, 2015 | 02:05 PM
  #29
Juanra's Avatar
I has a 4 puck solid center ACT clutch and a custom made twin diaphragm pressure plate made of two Exedy Daikin.
Have in mine that I have a X3 tranny and that it is push not pull. The car does not have good tires and it there is no traction there is no clutch slip.
Old Mar 11, 2015 | 02:08 PM
  #30
JonGTR's Avatar
Did Exedy make that custom plate for you? Or did a local shop?
