Any 400+ horsepower cars driving around?
Old Mar 8, 2015 | 10:03 PM
tdonnell's Avatar
Here is my dyno graph with STD correction and smoothing of 4. Ambient temp was 71 Fahrenheit with humidity around the 40% range:
This was with a stock bottom end on 25 PSI of boost on E85 fuel. My 870cc injectors were at 100% duty cycle and I'm sure the walbro 255 was nearing its limit also...
Old Mar 8, 2015 | 10:55 PM
i8acobra's Avatar
Vehicle: '14 Ford F-150
Have a larger image? Can't really read it.
Old Mar 8, 2015 | 11:38 PM
tdonnell's Avatar
I tried uploading a larger image from my photobucket but the forum website won't let me do it.
Here is a link to the image instead:
Dyno Graph
Old Mar 10, 2015 | 01:17 PM
Juanra's Avatar
Vehicle: 1997 Beta Swapped Accent
This is one of my Accents (one NA and one Turbo both Beta swapped)
Old Mar 10, 2015 | 03:00 PM
JonGTR's Avatar
^^^ Do you have a build thread with more details?
Old Mar 10, 2015 | 03:09 PM
Juanra's Avatar
I didn't build this one, I bought it from a fiend that had it under a tree for about 8 months after he bought and had it tuned.
I have almost all the information, any questions just ask.
Old Mar 10, 2015 | 03:17 PM
JonGTR's Avatar
What fuel pump and feed line size?
Stock cams?
Stock head?
What size throttle body?
Is that a custom made intake plenum?
What ECU?
Old Mar 10, 2015 | 03:27 PM
Juanra's Avatar
What fuel pump and feed line size? Walbro 255 the lines are bigger but do not know the exact size.
Stock cams? Yes
Stock head? Yes
What size throttle body? 90mm (I think its to big, I plan to test with a smaller one)
Is that a custom made intake plenum? Yes, a ebay intake manifold for an Mitsubishi Evo (I have a AIRRAM that will test also)
What ECU? SDS EFI EM-4 (www.sdsefi.com) and Water/Meth injection system (www.alcoholinjectionsystems.com)
Old Mar 10, 2015 | 07:22 PM
ScoupeLS's Avatar
Vehicle: 2003 Tiburón GT
that's a very nice and steady AFR.
Old Mar 10, 2015 | 11:57 PM
i8acobra's Avatar
You PR guys like running 'em lean... Unless that's on E85.
