aem fic wiring
finnally got my fic yayy only wires or sensors im confused is the crank and cam, do we have mag/vr or hall style sensors? how many of each? theres alot of wires that are deff not gunna be used lol
We got hal style. Make sure you use the right way. You should intercept the signal not tap!!!
sweet thanks man
I wired everything as the instructions told me and the car cranks but dosent stArt. Brought my battery to autozone they said it had a 60 percent charge. Does this have anything to do with not starting
Cranking but not starting makes me think crank position sensor related, but wiring in an FIC is a whole can of worms by itself. The low battery should be charged before reuse but as far as battery power is concerned generally if it can crank it should start.
Very true, how are you Taping the Injector drive signals? That was my issues, I F'ed it up, i would spark, and get fuel, but all at the wrong time, cause i am partailly color blind, and confused up a color with another, and got my injector drive signal wire hooked up wrong!
Two big ones i would look at first, is Cam and Cranks sensor hook up, as if there wrong it will turn over but not start! |
the injectors are hooked up in out on the fic. I put 440 green tops and made a base map with fic but it's no showing the injector duty on the screen. Idk whats going on lolWell
