Adjusting factory wastegate
Old Jan 18, 2016 | 06:39 AM
Default Adjusting factory wastegate
So some people have stated that you can adjust the factory wastegate actuator in the Genesis to get more boost. This just seems like a bad thing to do, but was wondering what others thought about the idea of messing with it was. If it were me, I would just get a whole new wastegate, or a manual boost controller. Screwing with something that the factory sets, like this, is just asking for problems in my opinion.
Old Jan 18, 2016 | 08:12 AM
JonGTR's Avatar
It just depends on how the ECU reacts to increased boost. I honestly don't know the setup, but in most situations, you can just bleed off boost to the wastegate and that ends up being pretty reliable to a certain point. But if the ECU doesn't like increased boost and throws codes, then you'd have to fix that.
Old Jan 18, 2016 | 05:52 PM
i8acobra's Avatar
Vehicle: '14 Ford F-150
Most modern cars are too smart to use old-school tricks. I'm pretty sure the Genesis has an electronically controlled bypass valve (not a mechanical BOV). If the ECU sees an overboost situation, it'll most likely open the bypass valve and/or set a code. I'd just tune it. The boost can be turned up in the tune.
Old Jan 19, 2016 | 06:28 AM
I'm running a tune now on it (canned tune) which upped the boost quite a bit, and I ended up tossing my HKS BOV for a Forge unit. I would never mess with the factory wastegate though. Too many things that seem like they could go wrong. I would rather just get a new manifold and aftermarket WG.
