Accent Beta Turbo (Scaryed of more boost?)
Hey guy's.
I have a fully Forged Beta Turbo T3. All the parts are rated for at least 400bhp. I'm currently running very low boost and Bhp of around 190bhp. (Tuned By Aftermarket ECU) I'm scarred that my drive-shafts will snap or my gearbox will be eaten up leaving me miles from home. (BOth hyundai coupes) (Idk if its how i fit my engine but i can use them some have issues needing ones from other models) Can anyone tell me what they safely run long term. As car asn't seen much use yet. I'm using the oil in my gearbox recommended on the site for a turbo setup also. The engines mileage is 95K but as had new pistons/Rings ect. Thanks for your time and have a nice day. |
are you using the alpha trans and axles?
+1, also when you say the engine is fully forged what do you mean? Does it have aftermarket forged pistons and rods? Also you say it was tuned by an 'Aftermarket ECU'. Which one? And who tuned it? If your using Alpha axles and tranny then I would limit the power to about 300bhp to be safe and don't do any hard drag launches.
he said the gearbox and axles were hyundai coupes
coupe = beta |
Gearbox and axles are Betas.
Forged Rods and Pistons. The engine is bullet-proff. But my driving gear isn't (Stock oem Beta gearbox and axles) as all the mounts are welded.. also Woried about the bushes twisting with the extra power. Is there uprated bushes u can buy ? |
will the clutch hold up to more power
dont take advice from me on how to make a trans last....im at like #6-7 |
F.O.D. smashes through trannies man, it's gross
So are trans sh*t then ? :(
250bhp be fine then ?
ok :)
