2g Exhaust Manifold
Old Feb 22, 2006 | 12:44 PM
socerguy131's Avatar
Would a 2nd Gen Eclipse exhaust manifold bolt on to the beta 1 motor, I seen a guy use a 1gen exhaust manifold on his beta1.
but what I know is that the 2nd Gen exhaust manifold is an upgrade for the 1gen exhaust manifold. so I am thinking that the 2nd Gen should have no probleming fitting?
Old Feb 22, 2006 | 01:28 PM
supercow's Avatar
you'll probably need to modify it, you'd be best to just pick up some cheep headers. mine will be on the market soon. cool.gif
Old Feb 22, 2006 | 03:16 PM
wattsup4800's Avatar
Im interested in this as well, i believe he is reffering to the Turbo exhaust manifolds. The 2g is an upgrade over the 1g. I think DWEET has done this in the past, but correct me if im wrong.
Old Feb 22, 2006 | 03:23 PM
yes sorry should of reread my post
Would a 2nd Gen Eclipse Turbo Exhaust Manifold bolt on to the beta 1 motor, I seen a guy use a 1gen Turbo exhaust Manifold on his beta1.
but what I know is that the 2nd Gen Turbo Exhaust Manifold is an upgrade for the 1gen Turbo Exhaust Manifold. so I am thinking that the 2nd Gen Turbo Manifold should have no problem fitting onto the beta 1 motor?
Old Feb 22, 2006 | 03:28 PM
once again, the 2g is def an upgrade over the 1g due to larger runners. However, there are most likely some modifications that need to be done. I am very interested in this as well. You can buy a ported 2g exhaust manifold for $50 online.
Old Feb 23, 2006 | 07:42 PM
bump
Old Feb 23, 2006 | 07:43 PM
if i remember correctly you gotta get it ported where the manifold meets so that the ports will line up
and that the bolt holes are too small and need to be enlarged
Old Feb 23, 2006 | 07:46 PM
Alex01tib's Avatar
if ur askin cuz u need a cheap mani i got a stock manifold that was modified to fit a tdo5h or a T3, i got pics, pm me if u want
Old Feb 23, 2006 | 08:15 PM
QUOTE (faithofadragon @ Feb 24 2006, 02:43 AM)
if thats it thats not a big deal
Old Feb 24, 2006 | 01:38 PM
lilo shark's Avatar
why don't you just make a plate for your stock manifold for a turbo then you can customize it for any turbo you want.
