2.0 inch cold pipe 2.5 hot pipe? or all 2.5?
Old Aug 9, 2010 | 08:38 AM
bullseye17's Avatar
Vehicle: 2004 Tib
Default 2.0 inch cold pipe 2.5 hot pipe? or all 2.5?
i see some people using 2 inch to the intercooler then out of it to the throttle body they use 2.5 or 2.75. whats up with that? im just trying to maximize my power and efficiency.
i know that may help it spool faster, but will it drop off cause it cant flow after XXX rpm and XXX pressure?
Old Aug 9, 2010 | 08:53 AM
JonGTR's Avatar
If you're gonna stick with a stock motor, then go 2" all the way around. You won't have enough power to warrant the 2.5-3", and staying with one size doesn't require you to buy 2 kits, or buy pipes individually.
Old Aug 9, 2010 | 12:43 PM
daytonmvp23's Avatar
Agreed unless you are putting on a big bodied turbo 2 in is all you really need for a 2.0l car. now if you step up to say a g30 garrett or equivalent then 2.5 all around.
Old Aug 9, 2010 | 04:14 PM
Regit's Avatar
Vehicle: 2000 tib
^ totally agree with daytonmvp23^
