which stage clutch 2or3
i need your help guys!
which clutch should i get stage 2or3 i plan on getting 4-1headers,2,5inch catback, cai, 1,8lcam, s-afc and itc(if i can use them together?) and maybe only maybe i will go for ZEX or forced induction i repeat maybe
so your oppinions please
I agree with Decker...I too have been considering which to get (2 or 3) & I have no plans for turbo, but I do see a NOS kit not too far off in the near future
So, I'd go w/ 2.
However...before you get one. Sharkracing is coming out with a heavy clutch kit that should be MUCH better than the other clutchers *( NOTE: I'm referring to Accent clutches in the post) wink
So, I'd go w/ 2.However...before you get one. Sharkracing is coming out with a heavy clutch kit that should be MUCH better than the other clutchers *( NOTE: I'm referring to Accent clutches in the post) wink
Go with a stage 2 because you will probably find the stage 3 will make daily driving less ejoyable. You will not need a stage 3 for the mods that you are planning. Also for now, I would not worry too much about replacing your clutch unless you are in need af a new one. Wait until you burn out the stock one.
that´s just it mine is slipping horrendeously, and i do urgently have to replace it the car has 78000km on it, and i am wondering too if i should get a flywheel with that clutch or just have a friend of mine shave a little of mine
anyway i will probably go with the stage 2 as you say i would like too enjoy the driveability of my car
