SS clutchline
Old Oct 27, 2009 | 08:26 AM
UnnaturallyAspirated's Avatar
Vehicle: 1998 Hyundai Accent
QUOTE (faithofadragon @ Oct 27 2009, 12:18 AM)
um stainless braided hose technically lasts just as long as regular hose
being that its just a regular hose in the first place but has stainless around it
false.
braided hose is like regular hose but has a protective stainless steel mesh covering the easy to damage and tear, crack, sundamage, element damage hose..
it lasts much longer than regular hose.
and holds up to elements better
Old Oct 27, 2009 | 08:32 AM
yes but who cares about the OUTSIDE of a hose its the inside that matters
the inside stores the harsh corrosive chemicals
so explain how a stainless braid will prevent brake fluid from wearing the inside of the hose?
its like sayin your gonna paint the outside of a oak barrel full of acid to protect it from the elements...
Old Oct 27, 2009 | 09:40 AM
QUOTE (faithofadragon @ Oct 27 2009, 10:32 AM)
i have yet to see a rubber brake fluid filled hose degrade from the INSIDE.. keep the fluid clean.. and you dont get decay from the inside.
it's the outside of the hoses that always cracks or breaks or leaks or gets soft due to elements.. heat cold.. road salt.. debris.. sand.. dirt.. abbrasives..
Old Oct 27, 2009 | 10:08 AM
and how many times have you cut open a line to inspect it on the inside? hell if anything the braid will prevent you from inspecting the line at all
youd never tell before it goes bad
Old Oct 27, 2009 | 11:26 AM
With the stainless braiding keeping the hose from flexing it does last longer than regular hoses by quite a bit. It'll still corrode from the outside but without the line swelling every time it gets pressurized the effects are slowed down.
