short shifter installation
i have a question. a while back i recieved my SR short shifter for my 98 tibby. i installed the actual short stick but i didnt bother changing the bottom piece because to me it looked exactly like the original part. was i wrong in doing that? b/c i was having some occassional problems and i was wondering if it was b/c i didnt not install the new piece.
The bottom piece shortens the throw side-to-side; put it in.
Just remember to remove the retaining pin from the bolt head under the baseplate before removing the bolt, or you'll strip the poop out of the plastic on the base.
i already have a dremil...and i already installed the shifter itself but if you've seen the pieces that come, the shifter comes with 2 pieces, the piece that you connect the shift knob and the bottom piece, well that bottom piece looks identical to the original piece so i didnt change it. but i already cut out the part of the base to fit the rest of the shifter
