Shifting, Revs, and Clutches
If I'm not quick enough with my shifts, and the revs go down to idle (from around 3000RPM) before I let off the clutch for the next gear (say 3rd --> 4th), is it doing significant damage to the clutch considering that letting the clutch out brings the motor back into sync with the wheels?
I ask because I'm still not perfected on my rev-matching on the Genesis and it happens quite often. |
Originally Posted by Super G-Coupe
(Post 664286)
No, it shouldn't do "significant damage" to the clutch. It will probably wear out the clutch disk a little bit faster. I would be more worried about ruining the synchronizers. |
Unless you are braking, and sometimes even then, you should have your foot on the gas pedal to prevent this happening. Nevermind the clutch, it's hard on the passengers.
