RPW CLUTCH vs HVE CLUTCH
Old Jul 16, 2002 | 03:52 PM
Mogul's Avatar
I got the HVE heavy duty clutch when my stock one went at about 70,000 km. At the beginning it was quite heavy but after a few thousand km's it got much lighter, almost to stock. Other than that cannot say much. I have stayed N/A with only a few trinkets (i.e BBTB, Rampod, Catback, headers, chip etc.) Will have to ask the big boys with regard to its hp limits and so on.
Old Jul 16, 2002 | 05:57 PM
JAWS 021's Avatar
well i needed my clutch to support 300+
about 220 as a daily driver and 300-325 under nitrous
after speaking to a fellow insane MOFO, im going with a stage 4 kore clutch
kore has pretty much gone untested
Kore is cheap and im hoping it will hold up
if something goes wrong,... im sure they will help me out
i believe their clutch stage 4 is rated between 350-400HP
i have managed to use a stock clutch with 185whp+ and over 200 pounds of torque.... so the clutch wont be mistreated,... so i should be able to post favorable results
I will keep everyone posted on this clutch
it will be broken under NA power for about a month... and i do drive a lot *tib has 80K miles*
