Performance Brakes & Clutch
Old Jan 20, 2002 | 02:43 AM
^AnDre^'s Avatar
Default Performance Brakes & Clutch
Im lookin to upgrade the braking power on my tibby...ive been lookin at HDK and they have 11" rotars and stock size brembo brakes... the 11's are up there on the price but im not gonna be running my car on the track (closed circuit) all the time... in the summer i am gonna be running solo 1 with my tibby... what you guys recommend??? and is there any upgraded brakes for the rear wheels yet?
also i wanna get steel brake lines.. is it worth it? .. im sure it is tho..lol..
last question.. well its devided into two... ive been looking for a new clutch for a while.. i want something like a stage 2 or stage 3.. a street/strip clutch.. somethin that is good and wont blow on me cuz i will be runnin turbo shortly... which should i go with.. also i want to run a lightweight/ superlight weight flywheel... where should i get it from?? which is reliable?
Old Jan 20, 2002 | 02:46 AM
PungentOdor1's Avatar
Stage 3 is mostly turbo/super only. So if u will be running a turbo...I'd most likely go with it.
^AnDre^'s Avatar
also .. forgot to ask.. theres no sachs clutch for tibbys are there??? i bought a street/strip sachs cluch for my 944 and ooohhh maann was it ever ammazing !
Old Jan 20, 2002 | 02:48 AM
^AnDre^'s Avatar
where do i get it from???
i cant seem to find one at all... all i can find is for honda's and acura's.
where should i get it from.. i want somethin reliable that wont blow on me
Old Jan 20, 2002 | 02:49 AM
Holy buckets. All of these questions were ansered in the last week or so.
Try NOT to put 10000 Questions into one post. Each question, or at least each TOPIC should have it's own post.
There are 5-6 threads in your original one.
#1. Questions about HDK Brake kit
#2. Any Big Brake Kits out there
#3. Stainless Steel Brake Lines
#4. Rear Brake Upgrades
#5. Clutch reccomendations
#6. Flywheel Reccomendations.
If you would, please create each one of these as a seperate thread in the proper forum, and you will get much better answers back. Also, check the last week or so for the engine and braking forums, you just might find the answers to all your questions there, as all of this has been covered.
