People with Automatics.
Old Sep 19, 2002 | 06:29 PM
  #21
QS's Avatar
QS
Shadohh:
Actually, accent trannys I have found are pretty good. And dont heat up to badly.
I would sitll reccomend the same way.
But run it as a standalone. If something breaks. remove it. hook up the old lines. take it in smile.gif
So dont run it with the stock cooler? An what would break...
Also the level10 work was mentioned...
After the TQ upgrade would you recommened running it with the stock cooler?
