odd oil question
Vehicle: 2004 Hyundai Accent
As the image in this thread very clearly shows, all synthetics are the same.
amsoil (the crap i used) and redline appear to be nearly identical in those pics. this is supposed to make me want to use redline??? i'll stick with what works thanks.
not sure why stocker has such a hard on for redline, its not his car that oldschool dino oil is going into after all!
I had a hard time finding 75w-90 Gl-4 too. In fact, I had a hard time finding and GL-4 at all. To put your mind at ease, in my various alpha transmissions, I've run:
SAE 80 GL-5 synthetic
SAE 75W-90 GL-5 synthetic
SAE 80w-90 GL-5 synthetic
SAE 75w-90 GL-4 semi-synthetic
I've never blown a trans, despite the fact that I foolishly ran GL-5 for a while. The only difference is that you drain a lot of metal shavings out of a transmission with 10,000 GL-5 miles.
It will be fine if you run a few ounces of 80w-90 GL-4. I think you just got unlucky with your blown trans.
well f*ck. if i want a GL4 only gear oil it seems that there is only synth left available in the world after a long google search. the GL4 and 5 compatible stuff isn't supposed to be such a great idea...
