Hyundai Aftermarket
-   Transmission, Clutches, Shifters (https://www.hyundaiaftermarket.org/forum/transmission-clutches-shifters-30/)
-   -   need tranny help NOW!!!! PLEASE. (https://www.hyundaiaftermarket.org/forum/transmission-clutches-shifters-30/need-tranny-help-now-please-2841/)
xxxmonoxidechild Sep 26, 2002 01:57 PM
OK heres the dillio yo, im putting in a kore stage two racing clutch and a fidonza aluminum fly wheel. heres my dilema, i got the tranny totally unbolted from every thing but the damn thing wont come off the engine? any ideas? i know i got all the bots off because i can turn the tranny around and i got it about two inches away from the engine, it just wont finish coming out???? me and three friend were using pry bars on the ***** and it still wouldnt come out? please help..
Stocker Sep 26, 2002 03:16 PM
http://www.hmaservice.com/webtech is your friend.
..moving to help forum...
xxxmonoxidechild Sep 26, 2002 03:53 PM
that site didnt help at all? damn it. i need to fix it now.... for the love off god, doesnt anyone have a clue??????
Random Sep 26, 2002 06:35 PM
I just went through this exact same thing.
Loosen the bolt on top of the lever arm for the clutch lever on the tranny. Raise the clutch lever up about .25 to .5" so it can rotate without hitting the housing. Now rotate it so the back end that was hitting the housing can now go above it.
This will release the clutch throwout bearing from the shift forks, allowing the tranny to be removed, leaving the throwout bearing, clutch, pressure plate and flywheel behind.
Tryptik Sep 26, 2002 06:41 PM
Yeah...
What he said... :D
Shadohh Sep 26, 2002 11:01 PM
Random is correct.
Also. Hope you have a clutch alignment tool and a new throw out bearing and some wee bit of grease.
Follow the proper HMA installation instructions concerning the reinstallion
xxxmonoxidechild Sep 27, 2002 01:59 AM
thank you random and others. i will get back to you all on how it goes.
xxxmonoxidechild Sep 27, 2002 02:47 AM
sorry bout the double post but the tranny is free. man the throw out bearing is shoved into the pressure plate and the pressure plate is deformend. ill update as soon as i can. thanks again guys. you all are true friends that i have never met. :D :D :D :D
Koreandude Sep 27, 2002 05:02 AM
hey mono, i encountered the same throw-out bearing fiasco too. Mine was all jammed up into the pressure plate deforming it also. I wonder if there is any correlation between yours and mines? I had 91K on mine when i replaced it.
Shadohh Sep 27, 2002 05:09 AM
As I remember, the throwout bearing is connect to the pressure plate by a snap ring. You need to remove the snap ring to get the bearing off.
The pressure should be deformed a bit, hyundai ones are weak ass *****es.
