k-spec gear ratios
Random:
Here's the stock info...
Transmission Ratios:
1st: 3.462 2nd: 1.950 3rd: 1.393 4th: 1.031 5th: 0.825 Rear Gear Ratio 1: 3.650:1
1st gear 6500 RPM 37 mph
2nd gear 6500 RPM 61 mph
3rd gear 6500 RPM 86 mph
4th gear 6500 RPM 116 mph
5th gear 6500 RPM 145 mph
Random, what model year Tiburon do these specifications belong to? My '97 1.8l 5speed aren't near those figures. My gears max out as follows..Here's the stock info...
1st gear 6500 RPM 35 mph
2nd gear 6500 RPM 58 mph
3rd gear 6500 RPM 80 mph
4th gear 6500 RPM 105 mph
5th gear 5500 RPM 125 mph (can't go higher..govrn'd)
Now, Autotrader lists a slightly different set of ratios for my 97 5speed 1.8 when compared to that of webtech so i'll go with webtech for obvious reasons.
However, 1.8's during 1997 have different 4th and 5th gear ratios than 2.0's...
1.8l Fourth 1.061
2.0l Fourth 1.031
1.8l Fifth 0.878
2.0l Fifth 0.825
Obviously the 1.8l has shorter ratios, but the final drive is the same @ 3.650
So why doesn't my 1st gear hit 37 mph or my 2nd gear hit 61 mph? My 0-60 times are slower because i have to make the 2-3 upshift @ 58 mph. Arrgg.
Right now i can't make sense of it when the 1.8/2.0 have the same final drive. The speed vs. time graph should be the same between the 1.8/2.0 until i hit 4th gear. And 4th gear is different like it should be....105 mph @6500 vs. 116 mph @ 6500.
What do you guys think??? Random??? suicide
[ February 12, 2003, 07:16 AM: Message edited by: Koreandude ]
http://www.hyundaiaftermarket.com/webfiles...ications_mt.htm
Your speedo needle is probably off, or your tire size is different than stock, throwing your speedo needle off.
[ February 12, 2003, 07:20 AM: Message edited by: Random ]
yes, you're speedo is off. speedos aren't completely accurate. for instance, mine tops out at 35mph in 1st, 60 in 2nd, 85 in 3rd, and 110 in 4th. furthermore, your tach isn't completely on, either. i verified this with the s-afc, when i could see the actual rpms vs. what the tach read. if you want to play around with gear ratios, www.smokemup.com has a gear ratio calculator. if you want to play around with tire sizes and how much it will affect your speedo reading, go to http://www.miata.net/garage/tirecalc.html
with 205/40/17's, your speedo is 0.1% slow. 205/40/17 is about as close to the stock tire size you'll get with different sized tires.
smile.gif Awesome info Random. I'm printing it off and warmin up my calculator. Can anyone tell me
if K-spec has gears, I can not find anything on their menu that mentions em. Maybe I'll try to emailing em.
[ February 12, 2003, 12:22 PM: Message edited by: Maxx ]
There are custom gearsets available in Korea, but they are not CHEAP. I'm sure the Kspec guys could get them for you if you emailed them.
BTW...figure out RPM/speed based off ratios here..
First...calculate your exact tire diameter
then use this to calcuate speed/rpm
Bookmark this puppy for all of your auto-math needs or calculations
Keep in mind, the "acceptable" limit of error in speedo's is 5%. For tacho's it's also 5%. That meanst at 5000 RPM, you could be showing 4750, or 5250. Or at 50 MPH, you could be showing 47.5 or 52.5 MPH.
[ February 12, 2003, 12:22 PM: Message edited by: Random ]
Maxx:
Can anyone tell me if K-spec has gears, I can not find anything on their menu that mentions em. Maybe I'll try to emailing em.
Ehhh, for some reason I like helping Kspec out.Can anyone tell me if K-spec has gears, I can not find anything on their menu that mentions em. Maybe I'll try to emailing em.
Heh heh.. poke
lol wink lol
Final Gear 4.412 for better acceleration.
Final Gear 4.294 for better acceleration.
Just go to www.kspec.com, click on POWERTRAIN in the left hand side, and there they are at the bottom.
Listed as FGR's...
