I need a clutch?
Old May 13, 2002 | 12:00 PM
white-shark's Avatar
Default I need a clutch?
Hi guys!! I have a competition the next week, I don`t have clutch anymore! Where can I buy a clutch at least stage 2 for tiburon 1.8L!! I have the kit alpine, but I would want to buy the clutch in USA because is the shipping very fast for my country!! please help me!! i need the clutch right now!! any advice please! thanks!
Old May 13, 2002 | 12:08 PM
2 UNIQ's Avatar
UFB has a clutch for $90 and should be more than enough for your turbo set-up?
By the way how much boost are you running with the Alpine kit and are you using the unichip and head spacer!
Old May 14, 2002 | 03:20 PM
I run to 15 Psi sometimes!!! I have unichip and head spacer!!!!
Old May 14, 2002 | 03:36 PM
AzzY's Avatar
white-shark:
Hi guys!! anymore! tiburon 1.8L!! country!! please help me!! i need the clutch right now!! any advice please! thanks!
white-shark:
holy exlamation point batman! eek!
Old May 14, 2002 | 03:40 PM
rubenz2K1's Avatar
15psi sounds like a whole hell of alot. eek!
did you replace all the internals?
Old May 14, 2002 | 06:08 PM
15 psi with the head spacer should be good for about 250 to the wheels. That is the area where the stock pistions and rods go bad. Be VERY careful. VERY CAREFUL.
www.clutchmasters.com can get you a clutch for about $525, and they should be able to get it to you in a week, but at what shipping cost I dunno.
If UFB can get you a clutch in that time, go for it. $90 sounds a hell of a lot better than $525.
