High performance clutch
Old May 7, 2003 | 02:01 AM
Koreandude's Avatar
I would go with a Stage 1 of any brand. You'll appreciate the extra clamping force and long life without the sore left leg.
Old May 7, 2003 | 05:36 AM
Shadohh's Avatar
I strongly advise against a stock cluthc.
Atleast do a clutchmaster stage 1
stage 0 being OEM.
OEM clutch are very soft.
An even if you dont make any more power the stage 1 will act as a Extended Long life clutch, and Still have better girpp.
Old May 7, 2003 | 05:59 AM
Snowman's Avatar
Just clarification your left leg wong get sore with a 3 or 4. it's hydralic and your not going to notice that much more pressur eon your leg.
Old May 7, 2003 | 11:44 AM
SpeedFactor's Avatar
But I suck at manual. So with the new clutch i let it slip a lot more holding it down longer, hence the sore foot. power shifting every gear at the supermarket is rude.
Old May 8, 2003 | 08:06 AM
smokintib's Avatar
Thanx for all the information you guys made my decision easier. Now the only thing is picking which stage 1 clutch to choose
Old May 8, 2003 | 09:44 AM
Cuda-Turbo's Avatar
I would recommend checking out www.keyperformance.ca. They have Stage 1-3 clutches for Tibs and are located in Canada so you don't have to worry about exchange and duty fees. I am ordering the Stage 2 clutch as Key Performance tells me it holds very well up to 300 ft/lbs of torque.
[ May 08, 2003, 04:45 PM: Message edited by: Cuda-Turbo ]
