Gear ratios and speed calculation
Old Jan 26, 2005 | 06:27 PM
hamhead's Avatar
... Hello Kit, gear ratios are when each gear maxes out... not when it recommends to shift... LOL. Gears 1-4 are the same on the 2.0 as the 1.8, but the 5th on the 1.8 is shorter.
Old Jan 26, 2005 | 06:29 PM
Alex01tib's Avatar
QUOTE (Kit-Fox)
the stuff they say in the manual about shifting is full best fuel economy and least engine wear and thats best for the Tib and the engine etc, dont look at it if ur looking for high acceleration it says something like shifting to 5th at like 45mph or something LMAO
hamhead is talking about the actual gear ratio of the tranny, not when to shift...jeeze:eek13:
Old Dec 10, 2013 | 08:46 AM
JonGTR's Avatar
I needed to refer back to this because I lost my file. I had made tabs with several versions of the 4cyl tranny ratios. Props again to Dmitry for making this.
Old Dec 10, 2013 | 10:34 AM
Red Raspberry's Avatar
Could you add a sixth gear?
Never mind, I see the is an ancient thread. I'll see what I can do.
Old Dec 10, 2013 | 07:19 PM
Guys feel free to upload your files when you have added pages and/or filled in ratios. If you gave the sources of your gear ratio data that would be great.
Old Dec 11, 2013 | 04:56 AM
I modified the file for a 6th gear in the mph table. Where is a good site to host the file?
Old Dec 11, 2013 | 08:29 AM
JonGTR's Avatar
Yea, I thought about uploading when this first posted, but was too lazy to find a way to upload an excel file. I have all the Elantra/Tib 5speeds. I also added the missing 5krpm.
Old Oct 19, 2014 | 08:03 AM
morenojd's Avatar
Vehicle: 1998 hyundai tiburon g4gf
Hi...any one can tell me what can of transmision is comming in the hyundai tiburon 2.0 1998 g4gf because am trying to change the ratio of the ring and pinion for better take off..
Appreciate your help.
Old Apr 22, 2015 | 11:05 AM
JonGTR's Avatar
Has anyone used this to verify its accuracy?
