Gear Box Question
I own a 02 Accent GS, I know in the X3 Accents you could swap in the tib 5speed gear box.
Can I put a 5-speed gear box for the tiburon in my accent? I am imagining that I will need the gear box and cable's for a Tib. I work at a dealership and have driven the tib on many occasions and it's throw when shifting is considerably less smile.gif
Thanks
Thanks
Why not just install a short shifter?
For the cost, it would be cheaper to adapt a tibby short shifter to the accent.
The Beta tranny does bolt up to the Alpha motor if you are really determined. To the best of my knowledge, you still need to adapt the tranny mount on the beta tranny to the accent engine subframe.
The LC Accents have a totally diffrent shifter design to the Tiburons.
I do know that the SR short shifter does fit the 1st Gen Accents. With slight modifaction to the base plate and some washers it works great. Installed one for a friend.
