gear box oil check plug
Can anyone tell me where the manual gear box oil check plug is?!!?
I have looked under the car and have found what i think is the draining plug, drivers side next to the front wheel, yellow plug? I need to know what the level is as i want to remove 80ml of it and replace with the slick 50 gear box additive. I have been told by many that this stuff is great and having bought it i want to use it!?!?!? |
from the front of your car look at the trans (top view)-... find slave cylinder, then look down a couple of inches, there will be a black (14mm?)bolt that sticks out parallel w/ the ground. that is the filler bolt.
the drain plug is a goldish 24mm bolt at the bottom of the trans. be careful that whatever you put in your trans! make sure it is a api gl4 rated fluid! |
