early 2000 to late 2000 trans diffrences
Old Jul 19, 2002 | 04:37 PM
Shadohh's Avatar
Stocker:
5 stars for workedtib.
does the revised 5th gear retaining stuff mean you can put power into 5th gear without it shredding like it used to or is it still a weak link?
Nah, its basically the same gear, just, it wont have a chance to put off under load with high HP. The thing is, now that is has less chance to pop off (which to me is like a failsafe) it will shred itself first.
Old Jul 21, 2002 | 02:58 PM
Nitrous Oxide:
i heard if you change the tranny to 1.8L 5-speed from 2.0 5-speed, you'll be noticing some faster times.....
Only if you can manage to get into 4th or 5th gear in the 1/4 mile...
1.8
First
3.462
Second
1.950
Third
1.393
Fourth
1.061
Fifth
0.878
Reverse
3.250
Final
3.650
2.0
First
3.462
Second
1.950
Third
1.393
Fourth
1.031
Fifth
0.825
Reverse
3.250
Final
3.650
