early 2000 to late 2000 trans diffrences
Old Jul 16, 2002 | 01:27 PM
XtremePc's Avatar
Default early 2000 to late 2000 trans diffrences
what is the diffrences between the 2000 and earlier and 2000 and later tib and elantra 5 spd trans
as i have read that there is a diffrence
i picked one up for real good price it's supposed to be out of a 2000 elantra
is there a way i could find out what year trans i have
Old Jul 17, 2002 | 04:07 AM
JAWS 021's Avatar
hmmm
i know theres is difference in engines between 1st gens and 2nd gens
as far as tranny.... none that i can think of
the elantra has different gear ratios
the flywheel dept on the 2nd gen engine is also different from the first gen
but thats engine
well thats all i can think of for now
Old Jul 18, 2002 | 08:12 AM
flywheels are a tad different. Elantra has a taller final drive.
other than that, you should be good to go.
Old Jul 18, 2002 | 01:09 PM
J@WS 01's Avatar
Random:
I've check in my service manuals on manual transmission overhaul....and the 1.8 L 5 spd elantra do have a taller final drive.
Since the 1.8 and 2.0 are very similar and the 1.8 transmission will bolt up to the 2.0 Your acceleration times should improve?
Old Jul 18, 2002 | 02:48 PM
workedtib's Avatar
hey whats up guys not sure the production date of the switch but the beta's used two revisions of the same trans the m5bf1 and m5bf2 the only major diffrence is in the 5 gear housing in the m5bf1 there is only a double staked retaining nut holding the fifth speed onto the shaft in the m5bf2 they incorporated a small retaining plate into the housing cover. see 1st through 4th gear are actually inside the trans case but 5th is in its own housing so had no support they changed the design to renforce the fifth speed. i can shoot some digital photos for you guys if you would like let me know.
Old Jul 18, 2002 | 04:11 PM
XtremePc's Avatar
thanks for the help
trans came today and it looks good
for $350 delivered
ok another question
as fo the 5spd trans mount
is it the actual rubber moumt that needs to be changed or just the bracket on the trans
as the tranny i got came with all three brackets
and one rubber mount see pic
Old Jul 18, 2002 | 07:20 PM
Canadian Prairie Shark's Avatar
You would accelerate less and have a higher top end.
Old Jul 19, 2002 | 04:04 AM
*light bulb goes off in random's head*
You're doing a Auto To manual SWAP!!!!
From what I understand, you'll need to replace the mounts on both sides (tranny, and bolted to frame), and the rubber inserts that go with them.
Old Jul 19, 2002 | 04:12 AM
JAWS 021's Avatar
he he he
im really waiting to see this car
good to know we have 3 krazies in kali
Old Jul 19, 2002 | 12:27 PM
5 stars for workedtib.
does the revised 5th gear retaining stuff mean you can put power into 5th gear without it shredding like it used to or is it still a weak link?
