Crank pullys on an accent?
Old Oct 14, 2009 | 08:48 AM
Joey's Avatar
Vehicle: 2003 Accent
Default Crank pullys on an accent?
I want to put under drive crank pullys on my Accent. Does anyone know where I can find some and how hard are they to install?
Old Oct 14, 2009 | 08:54 AM
Bullfrog's Avatar
Vehicle: 2001 Tiburon
They arnt that hard to install, are you just doing the crank pulley or all the other pulleys?
Do you have air tools? If so it will make taking the crank bolt off a lot easier.
There is a DIY on RDT regarding timing belts that has a section about taking off the crank pulley. While not the same car the concept should carry over.
EDIT- the diy on RDT doesnt have pics anymore...
Old Oct 14, 2009 | 10:08 AM
As far as i know there are no currently produced underdrive pulleys for the Accent.
Old Oct 14, 2009 | 10:36 AM
na mods for a 4 cylinder is a waste of money
just save your money and buy a nitrous kit for 400 bux
Old Oct 15, 2009 | 08:16 AM
Joey's Avatar
Why are na mods not worth it? Im trying to get the most power I can by doing simple easy mods.
Old Oct 15, 2009 | 10:04 AM
The reason that it's not worth it is that by the time you've made 10% more power than stock with N/A bolt ons you could easily have made 50% more power with forced induction for the same cost.
Trust me, I could easily have built a nice turbo setup for the same cost as I've spent on N/A mods and I'm only up to 100whp.
Old Oct 15, 2009 | 10:23 AM
i had about 2000 worth of bolt ons on my car...and i only dropped about a second in the quarter mile
if i ever ran the nitrous at the track i probably would have dipped another second on top of it for about 1/4 of the cost
I/H/E/ will probably run you around 700...for 10-15hp
