Clutch whistling again !!!
Old Sep 9, 2001 | 12:28 PM
Accent GSi's Avatar
Default Clutch whistling again !!!
I've tried 2 hyundai dealerships and they have changed that thing on my clutch (clutch bearing??) three times so far ! The damn thing is broken again when I push my cluch pedal down it stops, when I release it whistles. So far it's been problem after problem. The car stutters to. Still don't know why. Anyways why car is going in monday and they are going to check it out for the fourth time ! rolleyes.gif
Old Sep 10, 2001 | 12:04 AM
I hate to say it, but something ELSE has got to be wrong with that clutch, or you have HORRIBLE technique.
Insist that they replace the clutch AND flywheel. One of the two of them must be out of balance/wrong to cause the bearings to be going out like that. On the 4th same repair...you can claim the car is a lemon and force the dealer to take it back. If you use that as leverage...they might come around and fix it the right way.
Old Sep 10, 2001 | 04:59 AM
leftside_ryder's Avatar
Think it might be a loose belt or something?
