Clutch Freeplay
Old Feb 1, 2003 | 01:54 AM
Sir Moof's Avatar
Default Clutch Freeplay
how can I set that? I forget, and I don't have access to Mitchell until monday.
I'm pretty sure I have to adjust the part I'm thinking about under the hood... but is there a way under the dash? Cause it's damn cold outside, and my garage isn't heated.
Old Feb 1, 2003 | 08:26 AM
Shadohh's Avatar
You can adjust the pedal. thats about it.
If you have freeplay. Somethings defective.
Fork or Bearing. or one of the cylinders.
Old Feb 2, 2003 | 03:47 AM
Sir Moof's Avatar
It's only about half inch of freeplay, that's it.
EDIT: Freeplay in the pedal, I should add.
[ February 02, 2003, 10:47 AM: Message edited by: Sir Moof ]
Old Feb 2, 2003 | 01:16 PM
batman's Avatar
Vehicle: 01 Tiburon
my car had that since new so i just let it be
Old Feb 3, 2003 | 09:02 AM
turbulence's Avatar
you need freeplay in the pedal.
::edit::
right after i did "the swap," i thought if i took ALL of the freeplay out of the pedal, that would aid in high-rpm shifting. well, i took it all out....so i thought. later that day, when i was driving, i would give it, say, 70% throttle, and the rpms would climb, but the speed wouldn't. it was because i took just enough out of the pedal that the clutch was disengaged just a enough to slip under high-throttle loads. yeah, leave some free play in there. wink remember, the release fulcrum only moves like 3 degrees. consider the distance you push the clutch pedal and 3 degrees.
[ February 08, 2003, 11:36 PM: Message edited by: turbulence ]
