Changing Transmission Fluid
Shadohh:
Automatics, come with a system setup with the radiator.
were they actually have coolant running through them.
They manual has no such setup.
Basically... tranny coolers cant be used on manuals.
I thought those were transmission oil coolers.... not a system to run coolant through the trans... but I could be wrong... I don't pretend to know a lot about autos...
point is.
Any cooler needs the liquid to be pumped through it.
The manual has not pumps to push the fluid aorund.
Also you dont need to feeel around.
Justopen the check nut... and pour into the little rubber thing on the top till it start coming out then close it.
and little more fluid wont hurt.
