Changing Transmission Fluid
Old Dec 9, 2002 | 06:02 AM
Shadohh's Avatar
Nah, you dont need to replace it.
Its like replacing the washer in the oil everytime ya change oil. only replace it if it leaks really.
it should only grind going into 2nd when you shift at 6rpms.
if it grins below that you need a tranny rebuild. your syncro is going.
Old Dec 9, 2002 | 09:42 PM
Decker's Avatar
Ok, so here's the drain plug, but where do you put the gear oil in?
And do manuals benefit from a tranny cooler?
Old Dec 10, 2002 | 03:13 AM
Shadohh's Avatar
Automatics, come with a system setup with the radiator.
were they actually have coolant running through them.
They manual has no such setup.
Basically... tranny coolers cant be used on manuals.
Old Dec 10, 2002 | 07:02 AM
tibby01's Avatar
Vehicle: 2001 Tiburon
Decker, I was wondering the same thing...how do you get the oil in the transmission
Old Dec 10, 2002 | 07:40 AM
Shadohh's Avatar
umm, there is a little rubber thing up lop you pull therubbed plug and put it in.
also on the front of the tranny there is abolt.
bah, I will scan some pics, later tonight.
Old Dec 11, 2002 | 01:25 AM
tibby01's Avatar
yeah, pics would be very helpful. Thanks in advance.
Old Dec 19, 2002 | 09:07 PM
Decker's Avatar
thankx shadow in advance. I was hoping to change my gear oil this weekend.
Old Dec 20, 2002 | 10:41 AM
Shadohh's Avatar
hey, I need to scan those pics!
Old Jan 2, 2003 | 10:21 PM
Decker's Avatar
hey shaddoh, how about those pics :-D
Old Jan 13, 2003 | 10:47 AM
EL Tiburon's Avatar
Go to HMA an click on your model, year. scroll down to transaxle/transmision, manual transaxle, go down to general and you'll see replacement of transaxle gear oil. There you go.
