Can I put a 1.8 flywheel on 2.0??
The 2.0 flywheel has the material on it to move the flywheel away from the block. If I remember right, might need to research, a spacer can be found on automatics for their flexplate. I did that research along time ago when I thought about running a 2.0 flywheel.
