Beta 6-speed transmission build
Old Nov 19, 2024 | 07:15 PM
SpoolinShark's Avatar
Vehicle: 2010 Hyundai Accent
Default Beta 6-speed transmission build
Follow along with my custom Beta six speed transmission!
I know that there is an actual six speed transmission for the Beta but it seems to be only available in Korea. I was doing some research a couple years ago in regards to a potential stronger transmission for the Beta and noticed similarities between some of the newer Beta II, Alpha II and 6 speed transmissions in newer Hyundai/Kias. From there I began a more in-depth research and built the following transmission
I think I'm going to call this a Beta 2.5 transmission.
Teaser pics for the time being!
Old Nov 19, 2024 | 07:17 PM
To start off this journey I bought three different Hyundai/Kia transmissions, tore them apart and pieced the parts together to make one custom transmission.
The transmission models I used are below.
  • M5CF2-1
  • M56CF2
  • M56CF3-1
These first pictures are of the M5CF2-1 transmission which I found to come in a 10-12 Hyundai Elantra Touring. I believe this transmission also comes in the 09-10 Hyunda Elantra and the early Kia Soul.
Old Nov 19, 2024 | 07:20 PM
These next pictures are for the M56CF3-1 transmission which is common in the newer Hyundai Veloster and Kia Forte.
Finally, the last set of pictures are for the M56CF2 transmission which should be found in the 07-08 Hyundai Elantra.
Old Nov 19, 2024 | 07:21 PM
Started to tear down the transmissions and you can see how similar these two are to each other.
The first two pictures are the M5CF2-1 and the last two are the M56CF3-1.
Old Jan 26, 2025 | 07:40 PM
Teardown of the M56CF2 transmission which is vastly different. This is similar to the M56CF1 transmission which comes factory in the MC Accent.
I did a side by side comparison of the various transmission internals. Listed left to right are as follows.
  • M5CF2-1
  • M56CF2
  • M56CF3-1
Output shafts
Input shafts
Differentials
Old Jan 26, 2025 | 07:41 PM
Here are some more comparisons but of the various shifter forks and the reverse mechanism. The shifter fork pictures are only of the M5CF2-1 and M56CF3-1 transmission as the forks from the M56CF2 wouldn't be compatible for what I was trying to accomplish.
Old Jan 26, 2025 | 08:17 PM
Even though the gears from the M5CF2-1 and M56CF3-1 look almost the same, there are some minor differences. Based off of the measurements, they are the same gear ratio and appear to be interchangeable.
Old Jan 26, 2025 | 08:22 PM
The first and second gear on both the M5CF2-1 and M56CF3-1 use a brass triple cone synchro. I noticed that third through sixth gears on the M56CF3-1 use carbon fiber based synchros. You cannot swap the synchronizers without using the corresponding gear.
