a bad slave cylinder cause clutch noise probs??
Old Jul 16, 2011 | 08:05 PM
Loneshark's Avatar
Vehicle: 2000 Tiburon
oh god, i thnk you would be the first ever to confirm a backwards friction plate... it very well could be that, but i think it would make more noise than that, but then again we are not there to hear it..... please say it aint so....
Old Jul 16, 2011 | 08:27 PM
Turboron_99's Avatar
Vehicle: 13 Gen Coupe Ult.
Well the only time it should make noise is when the clutch peddle is depressed letting the flywheels raised surface to slap against the PD!
Old Jul 16, 2011 | 09:09 PM
bigfishmoney's Avatar
im screwed, im absolutely sure the clutch release bearing is scraping against the pressure plate ringes while spinning.. and now its more obvious than ever that when i high rpm shift to another gear the scraping sound is heard again..
yet i did alter the slave cylinder more note that i did preform clutch slave cylinder mod a yr ago using same one..
Old Jul 16, 2011 | 09:21 PM
i think i did so install it backwards.
if anyone can help appoint me to the youtube video where that guy is displaying 3 or 4 different clutches and what went wrong with them., that would be great.
Old Jul 16, 2011 | 09:47 PM
Loneshark's Avatar
how is it that in 10 minutes you went from thinking it was the TOB, to it being the friction plate on backwards... stop driving it before it shatters and blows a hole in the bellhousing, take this puppy apart and take some pics for us ! so we can flame you, call you stupid. then move on ! LOL, just kidding bro. but pics would be nice !
Old Jul 16, 2011 | 11:17 PM
oh i found it.
Old Jul 16, 2011 | 11:19 PM
um yep its probably on wrong
Old Jul 17, 2011 | 03:13 PM
LOL So take a few hours, drink a few bears, tear it down, see if it is saveable, then reassemble!
Old Jul 17, 2011 | 08:15 PM
incorrect, sir
Old Jul 17, 2011 | 08:19 PM
The side of the disk that's raised is suppose to face the flywheel!
incorrect, sirthat is the raised side in the assembly photo
