5 things you should never do in a manual transmission
I always keep my hand on the shifter. I dont believe that it wear things out any faster than not putting your hand on it. And I would never engage my ebrake on a hill. I do keep it in neutral though when I'm stopped without the clutch pressed in.
If your hand sitting on it is pushing things against syncos it will wear them out. I did it when my Genesis trans started to sound like a can with rocks in it after the single mass. You would be surprised how little you have to push to cause that.
I rest my hand on the shifter too but I don't push it up or down in the gear it's in. I just rest it on top lightly. I've always done that since the day I learned to drive a manual. No problems and I did it in the Tiburon every day for 10 years too.
Resting your hand on the shifter isn't a problem for most front wheel drive cars because there's no direct connection to the transmission. This is typically only a problem where the shifter goes right into the tranny itself.
