1st gear really hard to get into
Old Jan 24, 2013 | 09:23 PM
  #21
If you leave it in first . . . how is first even being shifted-into? Is it not already in 1st?
Old Jan 24, 2013 | 10:52 PM
  #22
onecrazyfoo4u's Avatar
I leave it in first, but put it in nuetral and let the car warm up in the morning after I start it. Double clutching seems to work everytime for first and reverse though.
Old Jan 25, 2013 | 10:10 AM
  #23
And I also pull it out of first because if I leave it in first, my very first movement will give a slight bump as I let the clutch out. I slowly let the pedal out, and it'll delay about ~1second before the clutch actually engages and I start moving.
Old Jan 25, 2013 | 10:13 AM
  #24
....you live in california, there is no need to "warm" anything up
Old Jan 25, 2013 | 07:06 PM
  #25
Besides which, modern cars only waste gas and increase emissions needlessly when let to sit & warm up. Just drive away. If the engine is really bouncing the car you might need new or filled roll stops (lower engine mounts).
