Weight Reduction
Old Jul 11, 2005 | 09:14 AM
The stock Tiburon weighs about 2633lbs.
Reducing weight contributes to lower 60' times and less strain on the drivetrain. To reduce weight in your Tiburon, you can follow these steps. They are only suggestions and some are NOT legal on public roads and may NOT be safe. Use your own judgment when following these steps. Some are only for the weekend/track car. They are not in any particular order.
Mod - Weight (Stock) / aftrmkt weight (brand)
<u>Free Mods:</u>
Remove floor mats
Remove spare tire, jack, iron, floor/cover - 30.5lbs / 0.00lbs
Remove the two small brackets and bolts from rear hatch wall
Remove interior plastic panelling
Remove headliner
Remove center console
Remove carpet and padding
Remove passenger seat - 42lbs
Remove Rear seats
Remove Spare Seatbelts
Remove all plastic linings under motor and in fender wells
Remove black plastic louvers/honeycombs in front/rear bumper
Remove foglights and wiring
Remove hood prop (or replace it with something lighter)
Remove hatch strut props (or replace it with something lighter)
Remove cruise control system
Run on low tank of gas (full tank weighs over 100 lbs!)
Remove stereo
Remove Speakers (both rears = 5.3lbs)
Remove the antenna and the wiring to it
Remove long heat shield for exhaust system
Remove intake manifold brace/bolts from underneath
Remove front/rear bumper supports and foam (recommend to replace with lighter material)
Remove impact bars in doors (recommend to replace with lighter material)
Remove metal plate in the glove box cover - 3.0lbs / 0.00lbs
Remove stock battery tray
Remove anti-swaybars (for straight-line drag racing)
Remove plastic spark plug wire cover and side timing belt cover
Remove small counterweights on motor-mount and shift linkage
Remove intake resonator or replace entire intake system
Remove A/C system, including ductwork
Remove Heater system
Remove tranny/flywheel cover plate/bolts
Remove spoiler (for straight-line drag racing)
Remove hood under supports/bracing/skeleton and black heat pad
Remove windshield washer spray system
Remove windshield wipers and their motors
Remove power steering system - 15lbs / 0.00lbs
Remove airbag system
Remove ABS system
Remove charcoal canister
Clean your car!
Put YOURSELF on a diet
ECU covering
Firewall insulation
Remove tow hooks.
<u>Mods that require purchase:</u>
Replace stock wheels with lightweight aftrmkt - 18lbs (stock)
Replace windows with lexan
Use carbon fiber / fiberglass body panels:
- Replace factory hood (33lbs) with a fiberglass hood (18.5lbs). 14.5lb savings.
Replace stock motor parts with lightweight parts:
- Crank Pulley - 3lbs, 15.4oz (Stock) / 9.8oz (OBX) / 13.6oz (JSpeed)
- PS Pulley - 9.2oz (Stock) / 5.0oz (OBX) / 5.6oz (JSpeed)
- Water Pulley - 1lb, .8oz (Stock) / 9.6oz (OBX) / 1lb, .8oz (JSpeed)
*NOTE* weight on Jspeep water pump pulley includes the beta2 sub pulley in it, stock weight shown does not
- Adj. Timing Gear - 16oz (Stock) / 14.4oz (OBX)
- Flywheel - 17.6lbs (Stock) / 7.5lbs (Fidanza) / 8.36lbs (VHR) / 11lbs (Gripforce)
Replace stock battery with a lightweight battery - 36.4lbs (Stock) / 14lbs (Odyssey 680) / 41lbs (Optima Red Top)
Replace dash with carbon fiber
Remove stock gas tank and install fuel cell
Cut out spare tire well and weld in lightweight floor to replace it
Replace Driver Seat - 42lbs / 13.7lbs (Sparco EVO)
Replace steering wheel with aftermarket unit - 7.6lbs / 3.6 lbs (typical ebay wheel)
Replace the rotors and calipers with lightweight options
Run short exhaust system
Lighter radiator
Convert to manual mirrors, or remove the motors
Let me know if you have anything to add to this list.
Old Jul 11, 2005 | 09:32 AM
brian01tib's Avatar
Some thing to buy, too expensive for me, but titanium bolts, I think some people with evos lost about 20 lbs or something, also if you can make a titanium IM, or cf but I tink titanum is lighter because some people replace theirs on the 340r or some kind of lotus I remembered
Old Jul 11, 2005 | 09:58 AM
Mad_john's Avatar
you could just gut it out and sit on an orange crate...Trailer park style laugh.gif
Old Jul 11, 2005 | 10:10 AM
Most of these mods don't interupt the luxury of the daily driver.
I like to drive "fast with class", so I didn't do things like remove the seats and carpet.
But there are a couple things in there that most people would forget about or never knew before.
Old Jul 11, 2005 | 10:51 AM
Arctic Seraph's Avatar
C/F fenders is pointless....you're not going to get any huge gains from it. Keep it stock is fine.
Old Jul 11, 2005 | 11:53 AM
^ not for the money!
Old Jul 11, 2005 | 12:39 PM
sharkev's Avatar
Old Jul 11, 2005 | 04:29 PM
Mad-Machine's Avatar
Another thing you can add... the Tib's wiring harness is covered in foam up under the dash to keep noise down.. you can spend several evil days removing it.
Personally, all those ideas are great for a full on race car.. but not too practical for a daily driver.
Old Jul 11, 2005 | 04:35 PM
'treezy's Avatar
are aftermarket radiators lighter than OEM's? I would like to buy a bigger radiator but would also like to keep the weight down as suggested...
<div class='quotetop'>QUOTE (JonGTR)</div><div class='quotemain'>Lighter radiator</div>
Do you mean smaller, or aftermarket?
Old Jul 11, 2005 | 06:16 PM
They make lighter radiators than our stocker.
<div class='quotetop'>QUOTE (Mad-Machine @ Jul 11 2005, 05:29 PM)</div><div class='quotemain'>Another thing you can add... the Tib's wiring harness is covered in foam up under the dash to keep noise down.. you can spend several evil days removing it.
I thought I had added that already, but after looking at it for a while, I knew I was forgetting some things. I also forgot the firewall padding. It's just there for road noise, which I heard isn't much worse than stock.
<u>Mods:</u> Can you add "ECU covering" and "Firewall insulation"?
