Rust
Old Jul 30, 2007 | 01:15 PM
Kantizuni's Avatar
Vehicle: 2000 Turbulence
I know it's been b****ed about a hundred times in the past, but I haven't got my chance yet.
Got my car jacked up and set out to install my headers. I thought I was all smart when I got the factory exhaust manifold recall done late last year. I figured once they've changed it out for the recall, all the nuts would be nice and fresh and easy for me to take off, once I got my headers.
So here I am now. The manifold came off very easily, as anticipated. What I had forgotten all about was the downpipe coming off the manifold. Which was NOT taken off by hyundai when they did the recall. And now i'm fighting with 7 years worth of rust buildup.
I can not get these nuts off.
I soaked it down with PB about 3 days ago, and have tried again every night since then, soaking those suckers each time. This last time, my wrench flew off, my breaker bar skittered across the floor, and I rounded the edge off the nut.
So i'm pissed now. Thanks for listening.
Old Jul 30, 2007 | 01:32 PM
Alex01tib's Avatar
Old Jul 30, 2007 | 02:41 PM
funkypc's Avatar
just use a chisel and a hammer. That is what I had to do to get mine off. I ended up strectching the one nut but it did eventually come off. I just needed a new nut, but not bolt/stud.
Old Jul 30, 2007 | 03:11 PM
'treezy's Avatar
I think everyone should experience this at least once in life. LOL
Old Jul 30, 2007 | 03:32 PM
zoned019's Avatar
Vehicle: 97 Tib
I think we've all ran into this problem. It is very frustrating.
Just cut it.
Old Jul 30, 2007 | 03:45 PM
I'd use a dremmel. Those suckers make everything easier. I cut my engine mount using 2 dremmel bits. If you're careful, you can cut anything without the bits breaking. I'm betting you could slice two rusted bolts with 2 dremmel bits.
Old Jul 30, 2007 | 04:11 PM
Kantizuni's Avatar
Yeah, I need to buy a new dremel, but that's what i'm going to end up doing. I just wanted to b****. wink1.gif
My last dremel caught on fire...
If I do end up having to cutting the stud, does anyone know offhand what size I would need for a replacement?
Also, they look like they're welded on on one side..?
Old Jul 31, 2007 | 12:09 AM
blazin6969's Avatar
Its such a pain in the ass i was going to tell you to leave it alone for like a day and come back but you already did that, its weird but sometimes its better....
Old Jul 31, 2007 | 06:02 AM
You need a nut splitter. Used properly it will not harm the threads on the studs at all.
And here is a place to buy them if you cannot get one locally:
Northern Tool's Nut Splitter <--- click me!
Old Jul 31, 2007 | 08:22 AM
Kantizuni's Avatar
^^ That's pretty nifty. I should pick up a set of those anyway.
