Why Is It Always The Last Bolt?
Vehicle: 1998 Tiburon
Righ so I've gone and bought this beautiful strut bar from one of are fine members and received it today and in fine form. So I goes out to the tib with thee olde socket set and start peeling of the the nesessary bolts. I reposition the sensor without issus evrything is brilliant. Now I expect these bolts havn't been moved since 98 so I knew it wasn't going to be easy. about 1/2 an hour later im stuck on the very last bolt. Long story some what shorter its now stripped and im sitting here with a desperate cry for an idea on how to remove this beast. I bought one of those beautiful boinic wrenches (very handy) but it doesn't fit in the space provided! AHAHHAHAH Now what?
Just venting sorry...
^^ probly a strut tower bar as he had to move the sensor.
if it comes down to cutting them, you'll need a upper strut assembally. Otherwise you need a hardcore vice grips.
yeah, duh...didnt even realize that. i just assumed that because he didnt have room for a tool he was messing with the rear strut bolts which have much less clearance around them. there is plenty of room for tools around the front ones.
you do own socket wrenches right?
Vice grips man, Set it as tight as you can and squeeze the heck outta those things.
If you cant get a strut tower bolt after that i wanna see a picture of this damn thing lol.
You are trying to turn it counterclockwise right??
Is the hex stripped off the nut or is the thread stripped?
If the hex is stripped, split the nut and get a new 1. If the thread is stripped, cut /grind/ or whatever the nut off replace the strut.
to answer the topic, If it were the first bolt you would have stopped what you were doing and seeked help from a mechanic before getting to the end of the project.
