Fixing Slightly Bent Rims
I have a pair of Velox VX-8 rims that both have a slight bend in the outer lip of the wheel. I was looking at my car to day and got to wondering if this is something I could fix myself. As I said, the bends are very slight (both still hold air). Is this something I could fix with a mallet? Or am I just asking for trouble trying to do it myself.
probably not. not with mallet. altough pics will help.
you need to roll them on special equipment. sometimes rim should also be heat.
better if shop will do it.
If there is very small bend - I would go and just rebalance it and put on the back of the car
QUOTE (tibby01 @ Jun 11 2005, 09:24 PM)
youre asking for trouble. i would spend the 75 or so it costs to get them repaired correctly. with a mallet you cant be sure its in acceptable balance.
Actually, I was going to get them re-balanced once I did this. Still asking for trouble?
