Brake Related Again...
There's no way I can get to those bolts. I have a fix key on the bolt, but what can I counter act the nut with? There's no 14mm that fits in there because of the spindle and a wrench can't get in there and hold it secure, it can only get have of the nut.
QUOTE (Random @ May 1 2005, 09:12 PM)
Remove the 4 bolts that hold the rotor to the spindle/hub. They should then easily seperate with minor persuasion.
hey random, i just attempted to do my brakes today also, noticed that after i took the 4 bolts out,they still wouldn't come apart...persuasion still needed?
Now I'm wondering if the bearings on my old 97 were just THAT clapped out.
When I took those 4 bolts off, I just grabbed once side, had a friend grab the other, and it just pulled apart. (with some jerking and twisting necessary).
If all else fails... Try the machine shop.
