Rims rubbing
Old Mar 20, 2005 | 11:03 PM
Phenomenal_Thunder's Avatar
Default Rims rubbing
I got my new rims, they are 17 inch Konig Unknown's. I put them on but when i went to drive they were shaking really bad. I am not for sure why but i hope to have that fixed tomorrow. That is if the tire place i take them too can get it fixed. But my question for you is, is there anyway to make the rims not rub as much? I heard most people don't have problems with 17's but my rub a little when i turn real sharp and when i hit any kind of bump. So any tips to fix this problem would be very helpful. thanks guys
Old Mar 20, 2005 | 11:17 PM
Rd1tib's Avatar
This might be the hub-centric problem people have with rims on tibby's. i think someone had a similar shaking problem like yours.
Old Mar 20, 2005 | 11:19 PM
tanc's Avatar
Vehicle: 1997 Tiburon
Did you get an alignment and balance done after putting the rims on?
Old Mar 21, 2005 | 12:28 AM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
What tire size do you use on your rims?
Try to interchange front wheels and rear.
Old Mar 21, 2005 | 05:42 AM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
What year do you have. I hope that the shop realized you have a captive setup if you have a 96-99. That would suck.
I think it could be the hubcentric problem too. Where do you get the rings at anyway??
Old Mar 21, 2005 | 05:45 AM
hamhead's Avatar
Yeah, you definitely need to get the wheels balanced, thats why the car shakes. As to why your rims rub when you hit bumps, your struts might be going bad.
Old Mar 21, 2005 | 07:22 AM
There are a number of reasons why your rims might "shake" the obvious of course is that the tyres are not properly balanced on the rims. but here are a list of other reasons.
Tyres not properly balanced
Bent Rim (especially on the front)
no hubcentric rings installed on the hubs
WRONG hubcentric rings installed
Loose Lug nuts
96 through 98 had captive rotors with large bolts on the rim mounting surface.
Wrong bolt pattern
As for your tyres hitting the fenders, You did not mention if your car was lowered or not. If it is lowered, you are going to have to learn to live with it, that is the price you pay for 17s on a lowered tib. You also did not mention what size tyres you are running. Most people will recommend a 40 series for 17s on a tib to keep the speedo correct and to stop rubbing.
Also, what is the offset of your rims? Tibs like a LOT of offset.. around 40
Old Mar 21, 2005 | 07:28 AM
KayJai's Avatar
Mad's got it all covered,...
You gotta let us know that info and we can go from there.
Old Mar 21, 2005 | 07:43 AM
Loneshark's Avatar
Vehicle: 2000 Tiburon
yup i bet ya the captive rotor is the issue, makes me laugh, when I first got my rims, they forgot to take the rear captives screws out of the rear discs, and when i left and got on the highway, man it was ridiculous, LOL, the ass end of the car was shimmying and shaking like crazy, it probably looked so funny from the outside, it was unsteerable !!!!!!
Old Mar 21, 2005 | 01:56 PM
Not sure which year your Tib is... but if it doesn't have captive rotors, did you remove the screws holding your rotors on?
