wheel bearing installation
Old Mar 7, 2005 | 09:06 AM
zoned019's Avatar
Vehicle: 97 Tib
Default wheel bearing installation
i ordered a wheel bearing and am going to pick it up and install it today after school.
can someone give me a heads up on what to expect? any special tools i'll need? i have somewhat of an idea of how to go about replacing it...but i'm not totally sure, could someone who knows (or has done it) post a basic diy in this thread for me?
thanks
Old Mar 7, 2005 | 10:24 AM
silvertibbs's Avatar
Vehicle: 2004 Acura TL
If it's for the front, good luck, I have NO IDEA. As for the back it is one piece that you just bolt onto the rear axle. Pretty simple IMO.
To be honest with you I would have a shop do it if it's the front. I know you have to take a bunch of stuff off and then press the bearing into place. then reinstall everything. So, hopefully it's the back.
Old Mar 7, 2005 | 11:44 AM
Sparticus's Avatar
Vehicle: 97 Tiburon
you'll also need to have your car re-aligned...
buy a thing of bearing grease too. lube that sh1t up real nice
Old Mar 7, 2005 | 03:12 PM
zoned019's Avatar
Vehicle: 97 Tib
yes it is the front..
what sort of press? 20ton?
you're sure it has to be realigned? never knew that.
Old Mar 7, 2005 | 03:54 PM
nihildark's Avatar
yeah, anytime you mess with the wheel/axle assembly you're going to need an alignment. plus is gives a mechanic a chance to spot any mistakes you make. good luck
Old Mar 8, 2005 | 08:52 AM
zoned019's Avatar
Vehicle: 97 Tib
*bump
can someone (S-F?) give me some more info on this 'press' ? please.
thanksss
Old Mar 8, 2005 | 10:13 PM
zoned019's Avatar
Vehicle: 97 Tib
another bump .. anyone have ANY info at all on how to install front wheel bearings? if i don't get any replies by tomorrow i'll stop by the shop after school, i need to be able to drive my car again. i got the bearing today.
Old Mar 8, 2005 | 10:51 PM
I wish I could help you man, have you checked webtech?? I dunno, you need some sort of press, I'm not sure. I always get those done by the pros.
Old Mar 8, 2005 | 10:56 PM
