Not sure if anyone else is experiencing the same problem as me where i cant view my PM,s.........
There are two icons saying Arcade and donate reading over top of "MY FRIENDS" and "New Messages" headings.... ANy help wouyld be great! |
It sounds like your resolution is too low (or your browser isn't maximized). The buttons form a second row if they can't fit across the top.
Can you make your browser larger? What resolution are you running? Try this link to access your PMs. http://www.rdtiburon.com/index.php?act=Msg&CODE=01 |
What skin are you using?
I tried to set even my text size to the smallest and nothing changed...I trieed every possible way and also the screen size decreases BUT not the wording....weird. mad.gif
Im using the Blue skin |
Thats the default skin, so it doesnt make sense that its not showing up for you. Can you do a screen shot and post it so that I can see exactly how much is being cut off? I can determine then if its on RDT's side, or your side thats causing the issue. smile.gif Thanks.
Also, what OS, screen resolution, and browser are you using? |
I tried playing with the screen size and NOW it works!!!!!!!.I tried playing with it last time and nothing happened.Only problem is my font size is smaller
Anyways thanks for all the help guys fing02.gif |
