Jattus Garage Sale - Lots of Misc. Parts!
Old 07-15-2018, 10:30 AM
Mahonroy's Avatar
Default Jattus Garage Sale - Lots of Misc. Parts!
Hey guys, I have a lot of misc. Hyundai Elantra/Tiburon I4/V6 components, including a lot of turbo components. I figured it was time to have a garage sale! As many of you know, I have been slowly transitioning away from turbocharger kits and more into electronics, so you can definitely get a deal on some of this stuff.
Shipping for any of the small things will most likely be between $5-$10. Some of the larger items shipping might be closer to $20. Some of the larger/heavier things we will need to see what shipping costs (I can provide estimates though). There are some heavier items that would probably be preferable for a local person to pick up as well.
I uploaded a few images you can use for reference as well, but this is the gist of it:
_
  • Maintec Turbo Manifold - Originally 1100 300
  • Jattus Top Mount Manifold - TD05 Flange (incomplete) 300
  • Downpipe For Top Mount Manifold 60
  • 16G/18G/20G TurboDischarge Flange 25
  • Elantra/Tiburon Jattus Manifold Jig 300
  • Kia Soul Jattus Manifold Jig 300
  • Hyundai/Kia 4 Cylinder Oil Return Block Drill Guide Jig 30
  • Engine Coolant Taps -6AN (individual) 20
  • Turbo Oil Drain Flange w/ Fitting -8AN 9
  • Delta V6 Engine Head Exhaust Manifold Flanges (set) 90
  • FMU 30
  • Bosch Electric Intercooler Pump 317GPH 12V Air Water 70 SOLD
  • Vacuum Manifold 15
  • Eastwood Bead Former - Originally 140 80
  • Honda Intake Manifold Flange 50
  • Honda Throttle Body Flange 25
  • 16G/18G/20G Internal Wastegate Actuator (12psi) - Originally 50 15
  • 2004 Hyundai Elantra Axle CV Boot Kit - Originally 25 10
  • Carbon Fiber Pillar Pod w/ boost and narrow band air/fuel 50
  • 2004 Hyundai Elantra Shop Manual 25
  • TB25 Turbo Discharge Flange 25
  • TB25 Turbo Inlet Flange 15
  • GT28 Ball Bearing Turbo (genuine Garrett), probably needs new center cartridge/rebuild - Originally 1200 300
  • Misc Turbo 30
  • Infinity G35 Oil Pan Spacer (increase capacity & oil return) 60
  • 3 Bar MAP Sensor 15
  • 2004 Hyundai Elantra Windshield Washer Fluid Reservoir 15
  • Oil Catch Tank 15
  • Water-To-Air Intercooler (Barrel Style) - Originally 190 110
  • Water-To-Air Intercooler Radiator/Heat Exchanger - Originally 150 100 SOLD
  • Custom Intake Manifold - Beta/I/II, mustange throttle body flange, w/ fuel rail 200 SOLD
  • Water-To-Air Intercooler (Same Side Inlet/Outlet) - Originally 150 70
  • Water-To-Air Intercooler (Opposite side Inlet/Outlet) - Originally 150 70
  • Beta II Intake Maifold (2004?) 30
  • Beta II Fuel Rail (2004?) 20
  • KLS-8T6 Fuel Controller (will provide fuel maps for reference) - Originally 200 120
  • Oil Return Block Drill Guide 10
  • Sub Injector Weld On Bung - Originally 40 25
  • Water-To-Air Intercooler Subaru 2.5l Bolt In 200
  • Mustang 70mm Throttle Body (was using on Beta II engine) - Originally 130 50
  • Greddy Type S BOV (Genuine) - Originally 250 70
  • Engine Torque Damper Kits (Blue/Red, Beta II 2.0 & Delta V6) - Originally 150 80
  • Emusa 38mm External Wastegate 40
  • TB25 Turbocharger - setup for use with external wastegate 110
  • Beta I Head 25
  • Beta II Head 25
  • Beta II Engine Block 50
  • Delta 2.7L V6 Engine, on engine stand. A few sensors missing, mostly complete. Low compression 120
  • A Ton of different silicone couplers - Might be easiest to just stop by if you need some?
Thanks and let me know if anyone wants anything!
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
File Type: jpg
Old 07-15-2018, 11:30 PM
tibbytib's Avatar
Wow! That's what I call a GARAGE Sale!!
I actually need silicone couplings! Can I stop by sometime this week?
Also might be interested in the carbon pillar pod if it's for an RD.
Old 07-16-2018, 12:01 PM
Mahonroy's Avatar
Yeah definitely! I typically work pretty late on Mondays, Tuesdays, and Thursdays... but any time Wednesday, Friday, or the weekend works if you want to swing by. I'm in West Brighton.
Old 08-09-2018, 01:16 AM
Megladon's Avatar
Vehicle: Tiburon
Default turbo manifold
Any of those turbo manifold still available? If so shipping to 90302 California
Old 10-25-2018, 12:19 AM
tiburon974's Avatar
Vehicle: tiburon turbo 97
Very interrested by maintec turbo manifold. pm you.
Thanks
Old 10-25-2018, 01:10 PM
Juanra's Avatar
Vehicle: 1997 Beta Swapped Accent
Out of curiosity, is the maintec a T3 flange?
Related Topics
Thread
Forum
Replies
Last Post
99sharkbmr
For Sale
7
04-27-2016 11:54 PM
Tiburonsrule
For Sale
20
10-21-2015 02:37 PM
KeMiCaLDeaTH
USA - Northeast
12
04-05-2013 08:28 AM
slow 2K2GT
For Sale
14
08-12-2012 05:51 PM
Goose
External Appearance
3
03-08-2010 10:14 PM
Quick Reply: Jattus Garage Sale - Lots of Misc. Parts!
