Is it possible to hit 14's on a 100% N/A car?
Topic says all. All bolt ons, and zero boost or nitrous. Can an RD hit 14's easily or does it take a crazy amount of engine work to do it?
Edit This is on a 1/4 mile track with street tires...no slicks. |
i believe we had a member on RDT hit a 14.9 with a TON of N/A bolt ons and good tires.. he was a hell of a driver though..
I would say its Possible but very improbable.. |
here it was...
Tdonnell had some extensive engine work.. Odessit had only bolt-ons that I recall.. He was @ 15.1, not under like i thought.. #10 - Tdonnell 14.61@95.95 NA #11 - OdessitPashka 15.1@90.6 NA |
^^ Miss those guys :(
I ran a 14.9 with mine, but Tdonnell and I swapped "most HP" titles back and forth a couple of times. I also only ran a 14.9 because Vegas is one of the slowest tracks in the country. Slower than even Denver.
What was the idle like at that power level?
My idle was only slightly lumpier than stock. I had Cat Cams which were pretty mild.
What were your ganes with the colt cams?
You need to take your NA tiburon engine
and put it in an Accent. |
Gained 20whp with the cams, Airram intake and a p&p head. Did all 3 at the same time.
