Modified brake pedal for better heel and toe?
Old Dec 29, 2011 | 02:28 PM
blue2000's Avatar
Vehicle: 2K Tib
Default Modified brake pedal for better heel and toe?
All you auto x'ers...
Anybody out there ever modify their brake pedal or throttle pedal to get them better lined up for being able to heel n toe while braking/downshifting/turning, etc?
Old Dec 29, 2011 | 02:41 PM
I have never used heel-toe during autox, but did during my lapping day a lot. I have a pedal plate that extends the bottom of the brake pedal a bit to make it easier. It does help make it easier, but it can be done stock also pretty easily on an Accent if you have fairly large feet.
Old Dec 29, 2011 | 05:26 PM
wheel_of_steel's Avatar
I've got pretty huge clogs with which I can mash the pedals, its not a problem for me. LC pedals are pretty widely spaced though.
I had the idea of fitting an auto brake pedal that is cut into two halves, so then I can do skid steering, aircraft style.
Old Dec 29, 2011 | 06:47 PM
It would work. Need 2 master cylinders. And stopping in a straight line would suck. Had that on some of the tractors/heavy equipment I use to operate.
Old Dec 29, 2011 | 08:27 PM
If you remove the ratchet from your hand brake somehow, you would have a rear brake lever
Old Dec 29, 2011 | 08:37 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
^- Push the button?
Old Dec 29, 2011 | 10:17 PM
Turboron_99's Avatar
Vehicle: 13 Gen Coupe Ult.
^^^ remove the button, remove the spring under the button, reinstall the button! No more racheting!!!
Old Dec 29, 2011 | 11:14 PM
I think it'd be useful for autocrossing, but actually getting it to work IRL would be a whole different show bag.
Old Dec 29, 2011 | 11:45 PM
300D50's Avatar
I was thinking of using one of the Jeep/Buick electro-booster brake systems, and modifying it to not function as abs, but as a selective steering brake, tied to the buttons on the wheel.
Shouldn't be that hard to get your desired effect with 2 "line lock" solenoids.
The big issue is that Hyundai, and most other makers of FWD cars, tie right rear to left front, and right front to left rear, so the brakes aren't strictly rear/front...
Makes for some damn SQUIRRELY braking when one of the pairs has air in it...
Old Dec 30, 2011 | 11:14 AM
My Bronco has a foot pedal parking brake.
It is an automatic.
The ratcheting mechanism is broken.
I have a drift pedal.
