Increase pedal pressure for autocrossing
Vehicle: 2000 Hyundai Accent
Looking to increase my pedal pressure for auto cross competitions. Easy way to do this without breaking anything......GO!
brake pedal so i have a little more power to go around corners. i already have stainless steel lines with new pads and rotors. but the pedal could be firmed up a bit. i bled the lines and the pedal still feels a little squishy.
Are you sure theres no air in the line you bled them properly? When I swapped my lines out for stainless, the pedal was definitely firmer than before I swapped everything. What conditions are your calipers in? If they need to be replaced that can cause a squishy pedal too.
